12-21-2019, 02:45 AM   #16
Class A's Avatar
QuoteOriginally posted by intense Quote
So, any tranceivers which can use several radio channels will be okay to use?
No, if you want control from a X2T-P, it has to be the Flashpoint R2 Single Pin Transceiver I linked to in my previous post, or one of the other compatible (but more expensive) Godox/Flashpoint receivers.
Sometimes I just need a manual flash to light up the background, but I assume it should be able to reduce power down to 1/64 for instance.
If you want to remote control the power of the flash then the single pin receiver won't be the right choice. You'd have to use an X1R but you'll have to have a compatible flash then. Unlike the Cactus V6 II, for instance, the Godox receivers are not multi-brand compatible. So the particular flash models you have won't support remote power level control with Godox/Flashpoint radio triggers.
12-29-2019, 07:45 AM   #17
Does anyone have missing fire with the X2T-P + AD200 or just mine? It act like
1. fire
2. no fire
3. no fire
4. fire
in random order
12-29-2019, 03:25 PM - 1 Like   #18
QuoteOriginally posted by mactrash Quote
Does anyone have missing fire with the X2T-P + AD200 or just mine? It act like1. fire2. no fire3. no fire4. firein random order
Hello. I own several Godox triggers, some are faulty, some have occasional misfires, others never had a single misfire. In summary:
FT16: never got a misfire
XT16: never
XT32C: never
XproC (unit 1): around 3% misfire rate. Also fails changing power in a similar rate.
XProC (unit 2): never
XProP: occasional/rare. Not always sure if the trigger was the problem
X2TP: same as above
My advice is to change your trigger. It seems you have a high misfire rate (50% ?).
I assume you have fresh bateries in trigger/flash, tried several channels, etc.
Regards.
12-29-2019, 07:46 PM   #19
Class A's Avatar
Have you tried a channel scan?
Perhaps you are experiencing radio interference from a WiFi router or wireless phone.
Cleaning the contacts of the trigger and the camera's hot shoe may help as well.
Finally, make sure to use the locking mechanism of the trigger to ensure good electric contact between trigger and camera.
12-29-2019, 11:42 PM   #20
QuoteOriginally posted by morenjavi Quote
XT16: never
XT32C: never
X2TP: same as above
Regards.
Thanks for your reply ... already send the the shop and they will check with godox
---------- Post added 12-30-2019 at 02:44 PM ----------
The XproP don't have issue in the same location ... already send it to the shop will wait for their report.
07-22-2020, 05:39 AM   #21
Riggomatic's Avatar
X2T-P question for those that might still be following this thread or using this transmitter.
Will the X2T-P transmit TTL to all Godox flashes regardless of the intended manufacturer (V860ii-S vs V860ii-N vs V860ii-C...)?
Thank you
07-22-2020, 09:44 AM   #22
Hello. I think all the v860ii support Pentax TTL. Please check this thread (https_//www.pentaxforums.com/forums/125-flashes-lighting-studio/408644-wireless-triggers-p-ttl-cababilities-2.html#post5019079). Regards.
07-22-2020, 10:23 AM   #23
Riggomatic's Avatar
Thank you. I'll check that out too.
07-22-2020, 07:47 PM - 1 Like   #24
Kobie's Avatar
QuoteOriginally posted by Riggomatic Quote
Thank you
Here is the firmware list for all Godox Products.
The list includes which products can enable (wireless only with trigger) Pentax Godox X compatibility
GODOX PHOTO EQUIPMENT CO.,LTD Download
07-24-2020, 11:21 PM - 1 Like   #25
inkista's Avatar
It will, but the V860II will not understand the P-TTL signalling unless it's been firmware updated to be Pentax-compatible:
  • V860II-C: v1.7
  • V860II-N: v1.8
  • V860II-S: v1.7
  • V860II-O: v1.4
  • V860II-F: v1.2
  • TT685-C: v3.4 [no other TT685 "versions" have a P-TTL update, neither do the TT350/V350 models—only the TT350-P can do P-TTL)
  • AD200: v2.2
  • AD600 Pro: v1.3
The V1, AD400 Pro, and AD1200 Pro are P-TTL were compatible on initial release.
08-07-2020, 10:37 AM - 2 Likes   #26
Related to my first post, and the issues with legacy flashes.
I noticed a new firmware version for the X2TP on Godox site (finally). I have installed the new firmware but I still get the same issues with legacy flashes, unfortunately.
I'll keep waiting...
03-25-2021, 01:31 PM   #27
Marketplace Reseller
You could obtain remote power level control, including automated metering and HSS by using the Cactus V6II. You'd need three units (one for the camera and two for the speedlights).
Hey, just wondering if you can pair The Godox Xpro with Cactus V6II with Pentax AF540 II and it will work?
03-28-2021, 07:38 AM   #28
Class A's Avatar
QuoteOriginally posted by pentaxkid Quote
What are you trying to achieve?
If you want to use the Godox Xpro as a trigger and the Cactus V6II as a receiver then you are out of luck. The Godox/Flashpoint radio system is completely different to the Cactus radio system.
If you want to use two triggers on the camera at the same time in order to trigger Pentax flashes and Godox lights, this will work in general. Some functionality may not be available, though.
05-12-2021, 03:56 PM   #29
I'm having a PEBCAK moment. Does anyone know how to do trailing curtain sync with these triggers?
05-13-2021, 08:58 AM - 1 Like   #30
Class A's Avatar
QuoteOriginally posted by keos Quote
You can't.
No user issue here, the Godox triggers don't support it. RIP, Cactus.
ad200, cactus, flash, flashes, godox, hss, lighting, misfire, mode, photo studio, power, rate, shop, strobist, sync, trigger, unit
Disappointment due to Sigma 17-50 f2.8 on K50 haroon88 Troubleshooting and Beginner Help 25 06-23-2019 08:29 PM
Considering X2T vs V1 morenjavi Flashes, Lighting, and Studio 5 06-12-2019 01:11 AM
New K-1 disappointment harpoh Pentax K-1 & K-1 II 99 01-06-2018 02:34 AM
upgraded K-s1 to KP WiFi disappointment i_trax Pentax KP 3 10-09-2017 04:00 AM
Photography and Disappointment interested_observer General Photography 8 11-01-2014 08:55 PM
All times are GMT -7. The time now is 05:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
