Originally posted by dafiryde so would it be safe to say , that because we are using digal format that we are not getting the true output from our flash
Dave
Actually, you're getting it backwards.
The output is no different, it's all about the field of view.
Your zoom head does go to 85mm. However, 85mm on the flash, will cover the same field of view as a 58mm lens on a 1.5x crop factor sensor.
The number displayed under the digital format is the zoom of the flash in 35mm divided by 1.5. This is so you can match up the same numbers and be rest assured that they are covering the same area.
If you were to connect a full frame camera, it will just display 85mm instead of 58. It does not make the flash any stronger or weaker.
Sorry if I confused you with my previous post. Hope this makes more sense.
