Has anyone been successful in getting this to work?
We all know that the K-1 lacks second curtain mode within the camera body, but even with the KP that supports it I am not getting any success. Is the second trailing curtain in the KP only working for the inbuilt flash? I'll have to try with another Pentax flash.
It doesn't look like it's possible with either a Xpro or X2T to get any kind of delay happening. I even tried placing the V6ii on top of the camera first and then stacking the Xpro on top, and set the V6ii to have a delay, but the Xpro still fires first...
Anyone?
TIA
BB
Edit: tested the KP with the AF36FGZII, I can get trail curtain but only in P-TTL. That sucks... also its needed to be activated on the flash, setting it in the camera body does nothing, so I am concluding that the in camera body selection of second curtain in the KP is for pop up flash only... great... :/
Edit Edit: Mark as solved. F4 in the AD200 Menu is a delay that you can use.
