2 Days Ago   #1
Will the Pentax AF360II or AF540II do wireless PTL with the original AF540?
Looking for a second wireless P-TTL flash to go along with my AF540. Do the newer generation Pentax flash work with first generation units?
I used the built in trigger flash a lot on the K-7 and truly miss not having it on the K-1.
Thanks,
barondla
2 Days Ago - 1 Like   #2
pschlute's Avatar
QuoteOriginally posted by barondla Quote
Yes they do. You can use one to trigger the other in wireless (optical) mode. The slave can work with the master in P-TTL or simple dumb slave mode. The choice is yours.
For optimum flexibility you would do better to go down the wireless radio route however.
2 Days Ago   #3
For studio agree. Primarily use multiple flash for macro. Already having to carry an extra flash vs K-7. Radio means even more junk to carry out in the field. Not sure all the modes will work, and an extra level of 3rd party menus are added to the mix. Don't see much benefit for macro photography.
Thanks,
barondla
2 Days Ago   #4
pschlute's Avatar
Yes I understand. If your distances are close you dont need the radio.
2 Days Ago   #5
Paul the Sunman's Avatar
That's certainly the impression I have of how a lot of people are thinking on PF.
My only issue with optical P-TTL on the K3 is the slight delay between pressing the shutter button and the shot being taken when triggering an off-camera flash using the built-in. That would presumably disappear with radio. It doesn't seem to be an issue on the K1 (with my Pentax or Metz flash on the hotshot and the other placed remotely). So I'm not feeling a great need to go down the Cactus or Godox route.
Am I missing the point? Why is radio, with its extra trigger unit, the way to go?
2 Days Ago   #6
pschlute's Avatar
QuoteOriginally posted by Paul the Sunman Quote
There should be no delay. You trigger the shutter, which triggers the Master flash, which triggers the slave. Radio would be the same timescale
Line of sight and distance and ambient light levels are no longer a barrier. With optical triggering these can be an issue. With radio they are not.
If you do all your slave work at close distance in less than bright conditions then optical will work fine for you.
2 Days Ago   #7
Agreed, there should be no delay. But there is.
2 Days Ago   #8
pschlute's Avatar
Sorry , but I am not reading through a multi page 6 year old post to find out what your problem is.
With the K1 and radio triggers there is no delay. You will do better to start a new thread if you have an issue.
2 Days Ago   #9
I'm not asking for any help on the delay issue; it's a well known "feature" of the K3. I was just correcting your assertion that there is no delay.
2 Days Ago   #10
pschlute's Avatar
My assertion was correct. With the K1 there is no delay
af360ii or af540ii, flash, generation, lighting, pentax, pentax af360ii, photo studio, strobist
Manual control of AF540 in wireless PTTL? bdery Flashes, Lighting, and Studio 10 03-17-2014 09:46 AM
Wireless AF540 without pop-up paulelescoces Troubleshooting and Beginner Help 3 01-11-2010 02:28 PM
Metz 58AF-1 wireless modes, same as Pentax AF540? AsahiMan Flashes, Lighting, and Studio 4 12-13-2009 09:41 PM
How to set K20D + 2 AF540 in Manual & wireless mode? HermanLee Flashes, Lighting, and Studio 4 10-21-2009 09:11 AM
K100D and Af540 fgz Wireless Roof Flashes, Lighting, and Studio 4 06-07-2008 07:57 PM
All times are GMT -7. The time now is 09:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
