Originally posted by Murfy Put 100m back on and again flash would only go off once in while.
Are you changing anything else at the same time, e.g., the position of the flash (I'm assuming it is an RF60, there is no "Cactus rx90")?
If the V6 gets too close to the RF60 (say less than 15cm, or so) than you may get a radio signal overload situation.
I recommend to put the "WORK RANGE" setting in the V6 to "SHORT".
In very rare circumstances, the relative orientation of the RF60 can cause some "radio blindness", i.e., the radio antennas align in a way that makes it impossible for the RF60 to receive a signal. However, if you only changed lenses and one lens reliably worked with the flash, you are not encountering this extremely rare situation (which is easy to fix by rotating the RF60 a bit and compensate the light output by counteracting the adjustment with a corresponding head rotation).
Perhaps also try using "M" mode with a shutter speed of "1/180s" or lower.
The "X" mode should work as well, but I never had any misfiring with the "M" mode and cannot speak to the "X" mode as I don't use it.
Originally posted by Murfy I have a lot of unexplained missed firing with cactus but this was so weird it was only on one lens. I think it’s time to upgrade.
The V6 uses a super simple camera-trigger interface: the centre contact of the hot-shoe.
Hence, there is practically nothing that the V6 can screw up on its own.
Any problem of the sort you encountered is almost certainly caused by the camera not creating a flash trigger signal, for whatever reason (provided there is no issue with the radio signal, see above).
If you were using a V6II, which can make use of the P-TTL protocol, the situation would be more complicated.
You'd have to make sure that the lens is recognised as supporting P-TTL flash photography. An aperture ring moved away from the "A" position could cause issues, etc.
The X-TTL firmware variant of the V6II is also a bit more temperamental than the multi-brand variant, at least from my limited experience. I tested some early X-TTL firmware versions, didn't like them and returned to the multi-brand version (I don't use the P-TTL features anyhow).
However, again, a V6 is agnostic to all of the complications added by P-TTL that using a V6II adds to the "game".
If you are having trouble using a V6, you are very, very likely to encounter issues with other triggers as well. On the contrary, more capable triggers may throw more sticks into your path because they rely on more variables, such as the lens being properly recognised by the camera and the trigger making good contact with the hot-shoe contacts with more than just one big fat centre pin.
