Originally posted by biz-engineer
Looking at eventually upgrading my monitor, I haven't found any easy way to evaluate the performance of a monitor for photography, without seing it in shop. Unfortunately, B&M shops have less choice than online shops. And it is not possible to see how a monitor render before purchasing online. In B&M shop I have seen some monitors but there rending did not necessarily correlate with the specs, so I find risky to buy online from looking a specifications online. There isn't any monitor review here or other photography / camera related sites. What are the key specs of a monitor to look at, definitions, where to find them?
This website:
Panel Search Tool - TFT Central
is a good source to find out what type of panel is in any given monitor.
Cheap panels are generally TN panels and are at best a 6 bit colour range and aren't much good for more than stenography.
The best ones are IPS panels, I believe H-IPS is the cream of that type, with those and MVA panels being the best there is.
Look for high gamut, the better panels will be hitting 95% or more of Adobe RGB colour gamut, and high contrast ratio.
I suspect that any IPS panel is going to be a good monitor.
I have used Eizo monitors and have liked them. I am using a Lacie monitor with is very good but takes quite a while to warm up, and a higher end NEC monitor which I am very happy with.
