Originally posted by BigDave Was the gel side toward the flash? In any case, if should not be that sensitive to heat! You may want to contact the company for more info..
Good luck!
Dave, there doesn't seem to be any difference in the two sides on mine. I did contact the company and they replied that there needs to be a gap. No surprises there with this response, but it is a bit of a cop out, as in reality contact is often likely and the gels should not be that sensitive, in my view. It would have different if I'd been firing them quickly on full power.
---------- Post added 12-31-19 at 08:28 AM ----------
Originally posted by swanlefitte I would expect at least 4-5 full power as quick as recharged to do this. I rubber band strips around or some with Velcro. They still touch but lightly and never came close with the 360.
I would think even glued on a few 1/4 power shots couldn't produce that heat. If in the soft box probably pull the wide angle diffuser down for more protection.
Hope you can clean it off alright.
I agree. Lower power shouldn't have melted it. It was a problem to get all the colour out of the groves in the lens. It would have to have been a strong red that I glued onto my flash. Now from some angles there is still a pink tinge of colour that can bee seen. Guess I'm going to live with that.
---------- Post added 12-31-19 at 08:29 AM ----------
Originally posted by dcpropilot I have never had a problem with the Rogue Flasbender products including their gels. From their website "Rogue Gels are made from the world’s highest quality materials from LEE Filters UK, the world’s leading manufacturer of lighting filter products". How tight was the gel against the flash? I always allow for a little bit of room between the flash and the gel (just enough so that the gel won't crease).
I did leave a small gap when I fitted it, but I guess when it was pushed into the softbox it may have tightened the gel a bit more. Lesson learnt ...
---------- Post added 12-31-19 at 08:32 AM ----------
Originally posted by UncleVanya My kit of rogue gels has never given me issues in my flashes including the af540fgz. I wonder if the softbox retained more great than normally would be retained by the flash?
My thoughts too. Plus the possible tightening when I slipped the flash into the softbox that might have occurred.
Reassuring to know it's not a common problem. I'll take care in the future ...
---------- Post added 12-31-19 at 08:35 AM ----------
Originally posted by yucatanPentax Since they're designed to mount directly to the flash, melting seems to be a big problem.[/URL]
My thoughts too. The instructions to leave a gap they sent me yesterday were not with the set I had - maybe I ignored them when I bought them a couple of years ago, or maybe they are now issuing the warnings with new kits ...
