Originally posted by mahanpots It's unclear to me what exactly SL-1 and SL-2 settings are for. My manual states:
"SL-1 when photographing in wireless mode
SL-2 when photographing with slave flash"
The manual does not do a good job on this setting. The use of the terms "SL-1" and "SL-2" are common flash jargon related to settings where pre-flash may be part of the mix. As noted above, SL-2 sets the flash as a "dumb" slave while SL-1 indicates a slave that is pre-flash aware. Depending on flash and mode, being aware of the pre-flash may mean participation in TTL flash automation (P-TTL slave) or ignoring the pre-flash while waiting a period of time for the real thing (most speedlights and some P-TTL models operating as manual or "auto-thyristor" mode optical slaves).
In regards to that last, I have used my Yongnuo speedlights set to "SL1" for optical triggering in conjunction with P-TTL optical wireless flash. The combination works great for some subjects and allows for quick setup of a partial-TTL solution without a lot of RF trigger* stuff.
BTW...excellent vase and most excellent product shot.
* Yes, I could also do this with RF, but with less simplicity and requiring a larger budget.
