02-06-2020, 12:18 PM   #16
Otis Memorial Pentaxian
QuoteOriginally posted by inkista Quote
You can mix group modes.
Interesting that this is missing from the manual. I'm not saying you are wrong, just that the manuals instruct one to set the flash to manual mode in order to master a manual mode flash.
That is also incorrect. It's not full passthrough TTL, but it's not manual-only either.
Illustrations for the Pentax version show a standard ISO, non-dedicated hot shoe on the top. Perhaps you have a photo of one with a Pentax-dedicated shoe on top?
AFAIK, no speedlights can be simultaneously a RF slave and an optical master or vice versa.
I was insufficiently clear, I fear and it may be that Godox may actually support this sort of thing. I sometimes use a mix of P-TTL and the YN560 III speedlights with the latter optically triggered by the former.* It would be nice to be able to mix the two with a wireless TX. The way it might work...
  • Godox X2T-P II or R2 Pro II triggered via wired PC
  • On-camera or built-in P-TTL (with or without optical slaves)
  • R600 speedlights controlled by TX
The enabling part is that the PC sync on Pentax is a separate circuit from the P-TTL sync. It only fires once and will do so at X-sync speed and below regardless of whether a P-TTL flash is active in the hot shoe.
* Have actually done a hacked SSH using the speedlights at full power with S2 optical triggering from an almost-nonparticipant P-TTL unit ...the duration is greater than the shutter dwell.
02-06-2020, 03:23 PM - 1 Like   #17
inkista's Avatar
For the group. Obviously, if you're not using TTL gear, setting the group to TTL doesn't work. But if you have a TTL light (AD200, V1, V860II) in Group A, and a TT600 on Group B, then Group B has to be in M for the power control to work properly. But Group A can be in TTL with FEC.
I stand corrected; I don't shoot Pentax and I don't have an X2T. I mostly go off Canon Godox system knowledge, and I keep forgetting Canon has the most functionality under Godox. The X2T Canon, Nikon, and Sony hotshoes are fully TTL-dedicated; it looks like the Olympus/Panasonic, Fuji, and Pentax ones are are not. YA different-system quirk to catalog [eyeroll]. Hang on... yup. Single contact on the X1T-O and X1T-F, too. Huh. Wonder why.
I was insufficiently clear, I fear and it may be that Godox may actually support this sort of thing. I sometimes use a mix of P-TTL and the YN560 III speedlights with the latter optically triggered by the former.* ... *Have actually done a hacked SSH using the speedlights at full power with S2 optical triggering from an almost-nonparticipant P-TTL unit ...the duration is greater than the shutter dwell.
That's a clever way around the pre-flash timing issues.
Yeah, that might work.
flash, ii, iv, lighting, nikon, pentax, photo studio, receiver, strobist, tx, yn, yongnuo
Can Yongnuo YN585EX be triggered by yongnuo trigger? swanlefitte Flashes, Lighting, and Studio 7 12-06-2017 07:37 PM
Confused camera, or confused operator? itiswhatitis Pentax K-30 & K-50 1 04-13-2014 12:23 PM
For Sale - Sold: Nikon D7100 w/ 18-105mm Lens (764 shutter count), Nikon 10-24mm, Nikon 35mm 1.8 Mlcinema Sold Items 4 08-02-2013 06:15 AM
All times are GMT -7. The time now is 11:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
