Originally posted by Apet-Sure One of the reasons I like the 283 is that it has a guide number of 120 at ISO 100 without any concentrating lens attached. Many modern units overstate their output power IMO by specifying it at the narrowest beam setting.
I'm getting the impression that the Vivitar 283 is the K1000 of the flash gun world. GN 120 : I have to convert that to 36 in metres, so respectable. Otherwise nothing special, and having no swivel head would rule it out for me because I could not take indoor portrait format shots bounced off the ceiling. The "Sold" prices on ebay are mostly £10-20; not as insane as K1000 prices but I've had a minty GN32 unit on Ebay,
with swivel, not Vivitar but probably made by the same people, and at only £5; but no-one was interested.
Originally posted by Apet-Sure Many modern units overstate their output power IMO by specifying it at the narrowest beam setting. ..... The 283 user manual shows the GN at various ISOs and with its different concentrating and diffusing lenses..... To do a meaningful comparison of the output power of different brands and models you would need a standardized specification for beam angle as well as ISO setting ....
Totally agree about the misleading hype, but most user manuals (at least of that era) will give the GN at different settings - seen after the user has bought it. Not only were flash units once sold on the GN at 100ASA and standard lens angle of view, but it was often part of the name. For example I have a Pentax AF280T (GN 28), a Jessops 300TTL (GN 30), and a Sunpak 4205G (GN 42). Americans using GN in feet might be less aware of this (my Sunpak was called the 544 in the US market for example).
Originally posted by Wheatridger Whenever I've used off-camera flash, I rely on optical or radio slave triggers. There's no way they can feed back voltages like a cord.
They could still fry the slave trigger unit.
Originally posted by Wheatridger When I hear about someone using the Vivitar 283, I just shake my head. ....A better choice in studio flash is the Metz 45. More powerful, more flexible, with excellent controls. I've used them since 1985 as my primary flash. Now mine is connected to my K-1 with a PC cord, with no harm done in thousands of exposures.
I believe that earlier Metz 45s did have a high trigger voltage, for example the 45CT1, and that it was only lowered in a later versions. So be careful.
