Originally posted by eoschneeman ...If I purchase the Godox x1r receiver, will that make my Pentax flashes work with the X-Pro trigger?
As has been noted, you can only fire the flashes remotely: no TTL, HSS, or remote power control. The X1R only comes in Canon, Nikon, and Sony flavors. This is one of the main differences between Godox and the Cactus V6II triggers: there's no way to integrate legacy speedlights into your off-camera lighting system.
Quote: Ideally, I would like to use 2-3 off-camera flashes.
The best solution, if you decide to stick with the Godox system you've "bought in" to, is to get Godox speedlights for off-camera and reserve your Pentax speedlights for on-camera use. The $60
TT600 is a single-pin manual flash, but has a built-in radio transceiver so you don't need to add a receiver to its foot to control it from the XPro-P, and you'll also get remote power/group control and HSS. No TTL, no remote zoom control. And, of course, being single-pin it's manual-only on a hotshoe. But at $60, it's only $20 more than an X1R receiver, with far more function, and getting 2 or 3 of them is affordable. [Hence
the Strobist recommending them now that the LumoPro LP180 is out of production].
In addition, built-in radio transceivers are far more convenient than add on receivers. You don't need to remember to pack them (or their batteries), and they speed up and simplify setup and tear down, and overall make for a more robust setup because you don't have to sandwich a receiver between the speedlight and stand, or find a way to secure a cabled receiver.
If you do want all the bells and whistles and will strictly be using these speedlights off-camera, there's also the $110 Godox
TT685-C speedlight for Canon. It can be
firmware updated to understand the P-TTL signalling from the XPro-P. Weirdly, none of the other TT685 "flavors" has this firmware update. If you shoot a second system and also need the speedligh to be TTL capable on-camera with Nikon/Fuji/MFT/Sony, then a V860 II ($180) of any flavor can also be firmware updated to be a P-TTL radio slave.
The TT350-P ($85) mini speedlight and the V1-P ($260) round-headed speedlight are the only P-TTL on-camera options in the Godox system at this time.
