Originally posted by swanlefitte
It seems logical to assume the focal length is pinned 1:1 to correspond to area of coverage of said lens focal length.
Area of coverage varies by distance and guide number is distance, literally, the distance at f/1.0 where the flash intensity will be sufficient for proper exposure within the scope of a 100% viewfinder field (the object frame). Yes, doubling the flash zoom will cover the square root of the area assuming the subject distance is the same as the old guide number with a 100% efficient flash zoom. Otherwise, the coverage area stays the same at the new guide number distance. I am not sure I have the calculation right, but doubling the focal length should work out to about +1 EV. In the real world coverage at the GN distance tends to decrease from the expected with increased zoom setting, however.
The Pentax P-TTL Flash Comparison site has a page dedicated to comparison diagrams showing composite diagrams for flash horizontal coverage angle out to the GN distance for all of several different flashes' supported zoom settings. Below is the diagram for the AF540FGZ (v1).
Addendum: The zoom settings overlaid in the diagram are (left to right) 24mm, 28mm, 35mm, 50mm, 70mm, and 85mm. Note that distance increase for 50mm over 24mm is somewhat less than expected (actual is 45m and 32m respectively).
When viewed together with those from other similar flashes, one can get an idea of how coverage is managed from one flash to the next. To see several at a glance...
Flash Burst Profiles - Pentax P-TTL Flash Comparison (Hint...the non-zoom flash serve as a reference point for the others.)
As noted on the two sites linked above, this is not something that lends itself to calculation or even estimation, but it best done by reliance on a flash meter, printed tables, GN multipliers, or the scales displayed on some flash model's rears.
Reason: Corrected math...again
