Originally posted by Leumas I need didn't think I needed TTL for HSS
HSS is a P-TTL-feature on Pentax, hence hardware supporting HSS needs to support at least part of the P-TTL protocol.
This doesn't imply that automatic flash metering or other P-TTL features will be supported as well.
The Cactus V6 II, for instance, supports HSS on Pentax without supporting any other P-TTL feature on a certain firmware variant.
Another firmware variant for the Cactus V6 II supports many more P-TTL features (personally, I never made friends with that variant, though).
@rawr You probably meant to write "Cactus V6 II" instead of "Cactus v6". The latter does not support HSS.
