Originally posted by Mercifulfate Pen.A.005
Have you tried using the generic firmware ?
Are you sure you are not seeing a Pre-flash "in the viewfinder" ?
---------- Post added 10-01-20 at 11:05 PM ----------
Originally posted by Mercifulfate I did not use TTL but shot it in manual mode on camera and manual on flash adjusting the flash power with the cactus V6II triggers.
I use V6II units together with Pentax Af540 and Cactus RF60x flash units.
The Cactus transceiver on the camera works as follows when wanting to use
manual control of flash output (at least with my setup and using the PEN firmware)
With the transceiver in Manual mode you need to set the flash units to P-TTL. I know this sounds counter intuitive but the transceiver uses the Pentax P-TTL protocol to send the correct power output (selected on the cactus unit on the camera) to the flash units. The process involves a redundant but visible pre-flash, followed by the main flash. The power of the main flash is dependent on the setting on the transceiver on the camera.
If you instead select manual mode on the flash units, you should get a single main flash which
should be dependent only on the setting you have selected on the flash unit. The manual power setting on the transceiver
should not play any part in determining the output. It simply sends a signal. However i did notice during the early days of the V6II that I would get unpredictable results in this method but only when using an older AF360 Pentax flash. It may well be you are seeing similar unpredictable results because you are using PEN firmware with no Pentax flashes, or just an unpredictable result anyway.
My suggestion is to turn the flash units to P-TTL and control the manual output with the transceiver manual controls. The only downside of this is that there will be a redundant pre-flash, which will cock things up if you are trying to use a flash meter to establish your exposure.
