Originally posted by ssssss Can I use it on K1 Mark2? I am not sure if it is high volt or low volt.
Assuming this is the original vintage version, the short answer is no, not without a voltage reducing adapter (e.g. SafeSync or similar). Trigger voltage is probably in the 300V range. This applies to both hot shoe and PC sync.
As for use with a wireless trigger, it depends on the trigger. Some brands have built-in high voltage protection; my Yongnuo RF603N II, for example, are safe with my Vivitar 283 (same innards as the 285).
Addendum:
I have had very good luck with the RF603N II and can recommend without reservation. The RF603 is sold in a two pack with either Nikon or Canon compatible hot shoe/foot compatibility. The Nikon version (RF603
N II) has better compatibility with Pentax cameras and dedicated flash. The Nikon version comes packaged with one of three different remote shutter cables specific to Nikon cameras, none of which work with Pentax, but a Pentax-compatible cable is cheap and readily available if you want to use it as a RF remote release. FWIW, these can also serve as transmitter to fire current-model Yonguo flash.
https://www.bhphotovideo.com/c/product/1096385-REG/yongnuo_rf_603ii_n3_rf_60...ess_flash.html
