Originally posted by Aaron28 thanks Steve.......i did this rather hastily with rear sync and will experiment more appreciate the suggestions to make further evaluation!!!
.....seemed that the 360 on the v6ii followed how cactus does rear sync.....the ad200 did not play along with the synchronization in either mode
yes! ................figured the ttl pass through would allow the x-pro-P function as usual but so far no using the specialized modes (hss & rear sync)
i can understand rear sync not working as it is not an available function to set on the x-pro but did expect hss to function......will note that if the hss mode on the x-pro was not 'on' the v6ii would not allow for ttl pass through.......when allowed the v6ii would display the "paperclip" icon
will try the experiments you suggest......manual may do the trick!
thanks!
I think Class A is on the right way.
I sold my V6II and non Godox Flashes time ago, but I remember that I did similar configurations with success. Sure you'll need the multibrand version, because X-TTL versions disabled the V6II's top shoe when you pass 1/180. Do you have a XT16R receiver at hand ?
This is an old thread where I told how I get HSS with the AD200 and XProC (canon version) stacked on top of the V6II:
here.
Also, here you have another post about how to get HSS with several Godox flashes and triggers, stacked on top of a V6II:
here.
These setups were done before the XProP 'era'. Surprisingly, XProP is less 'compatible' with the V6II stacked on top, compared to the XProC. Try the same configuration that I used in the second post for triggers like XT16/XT32, I think this is the correct path for the XProP, but maybe there are more ways to do it now. I don't have any Cactus trigger now, so I can't re-test XproP configuration.
Good luck.
Regards.
