Originally posted by giselag I would like the option to do both.
While it wouldn't help you use your existing Pentax speedlight off-camera, you could get Godox gear. A Godox TT685-C (for Canon) is $110, and can be firmware-upgraded to do P-TTL/HSS as an off-camera radio slave (it cannot be a P-TTL on-camera flash, though, since it has a Canon foot). And the Godox X2T-P ($60), XPro-P ($70), and Flashpoint R2 Pro II-P ($70) transmitters will let you do P-TTL and HSS, with remote power/group/zoom control.
So, $180 total, which is slightly less than 2x$95 => $190, which is what new V6 II transceivers cost. And you have a built-in radio transceiver in the TT685-C, so you don't need to sandwich a trigger between the flash and the lightstand. And you'll
be in the Godox system, which has a lot of larger light options, if you need them.
