Originally posted by othar Wouldn't waking them up take too long for the picture?
Another problem in my opinion (not for the picture but the wildlife triggering the camera) is blinding/scaring the animals with the flash. On a documentation I have seen some pictures done at night (via a triggering system) but I think they used a IR-converted camera and IR flashes to reduce the irritation for wildlife.
All the DSLR Trap camera systems I’ve seen on the web (and I’ve looked at a lot) use normal cameras and flash guns. Usually set the flashes to something like 1/8 to 1/32 and high ASA to avoid startling the animals and it doesn’t seem to bother them too much. Tried it out on the local cats which pass through the garden using a remote lead from the house and it’s the noise of the shutter that seems to be a problem not the light from the flashes. Next job is too build a waterproof case for the camera (locknlock food containers) and that should help cut the shutter noise down.
Wake up feature seems to work by sending a “half press” signal to the flash about a second before the camera “shoot” signal. Camera and flash then fire as normal
---------- Post added 11-26-20 at 02:24 PM ----------
Originally posted by Alex645 The Pentax AF540FGZ II is weather sealed and when in wireless mode will auto power off after one hour; it is a sort of sleep function, but you can't snooze for more than an hour.
The Godox V1 looks promising, but you'd have to email Godox for your specific question and this is assuming you would buy their wireless system for the Pentax.
The Metz mecablitz 64 AF-1 does have a sleep function that will wake up with the camera, but it's not weather sealed like the Pentax.
+1@othar about both the delay in the flash waking up and the flash blinding or scaring off the animals after a single shot. In fact, they will probably be first alerted by the ultra high pitch whine of the thyristor being charged before the shot.
Most critters are blind to a certain frequency of light, such as the amber color in darkrooms and sodium vapor lights. Have you considered running a motion detector to a/c lights instead of using electronic flash?
Thanks
Will have a look at the Metz flashes, weather sealing isn’t a problem as I’ve built weatherproof cases using locknlock food containers. The snooze mode on the AF540 would be a problem as the units could be left out for 2 - 3 days and I’d need them to be active all the time. Will also talk to Godox but that’s for the future.
From what I can gather off the net the capacitors in the SB28’s seem to be able to stay at full charge for several hours and retain enough charge to fire the flashes at 1/16 or 1/32 power without a recharge
---------- Post added 11-26-20 at 02:27 PM ----------
Thanks
