Originally posted by Lowell Goudge There have been some reports that the AF540 has "non uniform exposure" at 1/180th of a second flash sync of the K10D which could imply that the flash duration is longer than the maximum open time of the shutter and the trailing edge is moving before the flash is finished.
I've just now been looking into this, by coincidence. In the manual for the AF540FGZ and AF360FGZ, Pentax lists the duration at full power as 1/1200th of a second, and the fastest duration at 1/20000. But, that's described as "Flash duration (1/2 peak each)" — which means they're measuring what's called the T.5 time: the time the flash is brighter than the 50%-of-brightest mark. Online reading suggests that the T.1 time (amount of time the flash is brighter than 10% of the peak) is more useful as a gauge of ability to stop motion, and that generally the T.1 time is about 3× the T.5 time. That puts the full power duration at about 1/400th of a second, at least nominally. Given the user reports you cite, the actual number may be a bit lower.
Metz has nice charts in their AF-1 manuals listing flash speeds at each power. For the 58 AF-1, this ranges from 1/125th at full power to 1/33000th at 1/256th power. Metz has confirmed for me that this is the T.1 time — basically, less standard, but more practical/honest.
Quote: Having said all this, the AF540 is still perhaps the most versitile flash, due to it's abilitu to operate in P-TTL, TTL, "Auto" and Manual modes, and its ability to automatically switch between these modes depending on what lens you have installed on what ever body you have and the metering that body supports.
And don't forget off-camera P-TTL.
I think the Metz 58 AF-1 may win for flexibility — it also supports all of those modes, and has a longer zoom (105mm efl vs 85mm efl), more manual steps (25 vs. 7), and a secondary reflector for catchlights (not just a bounce card).
