Originally posted by mattdm So, does the non-P-TTL auto mode work in the camera's program modes (that is, anything but M) on Pentax or Metz flashes? This isn't a big drawback or anything — I just want to be able to explain it clearly.
Yes, exactly. The camera transfers all setting information (aperture, ISO and focal length) to the flash. The flash then sets the X-sync shutter speed or - if you allowed slow shutter speed sync - it works with any shutter speed equal or longer then the X-sync. The flash adjusts its reflector matching the focal length (within its limits).
This works with P, Av and Tv and M (apart from choosing the shutter speed) - I have never used the Green Mode, so I don't know how it works then, but I guess it does.
It comes even better. Metz flashes support their own wireless protocoll. So you can use several Metz flash guns (one as master, the others as slaves) and don't have a problem with getting the exposure right. This Metz wireless mode works with the Auto-Thyristor control and with the old TTL flash metering, but not with P-TTL.
Most Metz flashes can be used that way, if equipped with a special SCA adaptor (SCA3083), but the higher spec modells have the master and slave functions built in.
Ben
