Originally posted by mattdm Well the build quality is ok-ish. I don't through my stuff around and so far it has survived.
I only have another Chinese auto flash and their construction is similar but nothing like the k100d.
I've used both flashes, but I find the auto flash more reliable, but the p-ttl is faster. I used the p-ttl flash for some indoors football matches were it performed fine, but chose to use the auto flash for a wedding.
The only problem I've had with my flashes so far is that the secondary fill-in flash of the auto flash burned (it popped). You had to see the face of the poor bride but I assured her everything was fine.
I took about 1400 shots from 6pm to 3am with the poor flash. The small flash died only the next day after about 400 extra shots. I also had the p-ttl flash as a backup.
If I'd start from the beginning I would either look for a 285hv or a sigma 500/530 super. Too bad the sigma doesn't have an auto option.
