Originally posted by delboy65 ... i wondered about a few Godox - and noted that the, more powerful(?) TT600 is £ less than the TT350 - but now understand that is probably due to P-TTL..
Yes. The TT600 is a single-pin manual full-sized speedlight that runs off 4xAA. All a camera hotshoe can tell it is when to fire. It is also not firmware upgradeable. As a radio slave, however, it can do remote M power adjustments, sync, group control, and HSS. As a radio master, you only have sync and group and M power control.
Godox has been bad about supporting Pentax. Their
full speedlight lineup consists of seven models:
- TT350 ($85), mini speedlight, 2xAA. 270º swivel, no sync port, no battery port, no recycle beep. Small and light enough for mirrorless.
- V350 ($160), Li-on version of the TT350. (li-on pack has roughly 3x the capacity of a set of AAs)
- TT600 ($60), single-pin manual speedlight
- V850 II ($140), Li-on version of the TT600; lacks a battery pack port.
- TT685 ($110), TTL/HSS full-sized speedlight
- V860 II ($180), Li-on version of the TT685; lacks a battery pack port.
- V1 ($260), round-headed li-on speedlight.
But, when Godox brought out P-TTL support, they only made versions of the TT350 and the newest model, the V1, and never came out with -P versions of the older models. So, there's no TT685-P or V860 II-P, which, to me, are the two models that offer the best bang for the buck. There are rumors that Godox is going to be releasing V850 III and V860 III updates sometime this year, and that the V860 III will have a Pentax version. But. So far, there's been no formal release announcement.
Quote: So, if i went with a salvo of TT350P's .. would
1. they all be P-TTL,
Yes.
Quote: and 2. would that save me the need to buy a transmitter as well?
Depends on how much control you want over the off-camera units. An on-camera TT350-P can be a TTL/HSS radio transmitter that can control up to three groups (A-C). But. Unlike the dedicated transmitters, there's no bluetooth app control, no TCM (TTL convert to Manual; basically TTL locking), no groups D&E control, and no access to custom functions like "close mode" (DIST), SCAN (auto setting to the least crowded channel), or modeling light or zoom control.
It's a useable transmitter, but it's not as full-featured or small/light as a dedicated transmitter unit.
