Originally posted by WileyB Hello!
Does anyone using Godox have experience with either/both of these wireless controllers? Do you know if I buy a godox controller meant for another brand (olympus for example) does it work OK on a Pentax other than the ttl and maybe hss?
I want to start with 1-2 speedlights (model tt600).
Thanks for any experience anyone might have!
Wiley
Hello, I have both
About using a trigger meant for another brand, I used several triggers for Canon (X32C and Xpro-C) without issue. Of course you don't have HSS or PTTL, just control and triggering flashes at normal speeds.
XproP vs X2T-P. There are advantages and disadvantages, they are not exactly equivalent products. My most used is the XProP.
Positive points for the Xpro-P:
* Interface. The XproP doesn't have a fast and refined interface but for me is easier to manage compared to the X2T-P. With the X2T-P I push the wrong button frecuently, It's more difficult to handle, but this is just subjetive, other person can be used to this interface and find it easier to handle. If you have just one flash to handle, you can use the zoom mode. Then you can control a flash easier and faster by using this mode.
* Legacy flashes. The XproP supports old and new Godox flashes. The X2T-P doens't handle correctly old flashes like the V850 mk I or the mythical AD360 mk I. It's the most compatible trigger.
* 5 flashes at once. You can see data about up to 5 flashes on the screen, you can select ALL and change power values. The X2T-P can handle just 3 at the same time, and max of 5 flashes, the first 3 for TTL flashes, and the last 2 are handled as manual flashes.
Positive for X2T-P:
* smaller, not too tall, if this is important for you.
* shoe on top, this is a single pin shoe, but you can get HSS signal too. This is important if you want to stack another trigger or a (small) flash on top. You could use this flash only on manual mode, but it's an option that you have.
* focusing aid. This trigger have a nice red light to help focus in dark scenes. It has a nice pattern and it's better that the XProP's.
* advanced functions, like channel search, to find the best channels for your trigger, and DELAY SYNC, to play with high speed sync.
I have legacy Godox flashes, so my most used trigger is the XProP. But for doing 'experiments' I use the X2T-P (you can look at this
thread with one of my X2T-P experiments
Adorama has an updated trigger similar to the XPro-P but with more advanced functions and better interface, the Flashpoint R2 Pro Mark II, maybe it's the best trigger for Godox at present.
Regards.
