Originally posted by Lord Lucan I understand there were two types of sensor for the 283, the standard one which gives 4 Auto modes and a single full-blast Manual mode, and an optional sensor that has no Auto modes but does give a choice of manual power levels. Is that correct?
Yes, I have both. The other is not a sensor, but plugs into the same 4-pin receptacle. It is called Vari-power VP-1 and allows up to 1:32 attenuation by marked increment or continuous in a range from 1:1 through to an unmarked 1:64.
As for weight...a comparison with batteries:
- Pentax AF280T : 414g
- Sigma EF-610 DG Super : 436g
- Yongnuo YN560III : 472g
- Vivitar 283 : 494g
Yes, the Viv is the heaviest, but the Yongnou is in the same league. On the list above, each has its strengths with none able to do a full spread of how I use flash, at least not without optional accessories.
As for the foot on the 283, its construction is similar to the other three. Yes, the Yn560III has a metal foot, but has a plastic attachment the same as the rest. I think the reason why there is a market for replacements may be traced to the rough life assigned to pro tools in general and the loyalty of fans. FWIW, the replacement foot industry is still alive and well.
Considering guide numbers...I hope you don't mind my taking a somewhat deeper dive here. My experience shooting with the Viv 283 has been that is has coverage and power similar to the YN560III, with the AF280T being respectably powerful, but not in the same league. Based on published marketing specs, the Sigma in the list above is the most powerful at max followed by the Yongnuo. However, when normalized for comparable coverage, the four run like this:
- AF280T : 28(m), ~40mm FF (33° vertical 48° horizontal) *
- Viv 283 : 36(m), 43° vertical 60° horizontal (~31mm FF)
- YN560III : 30(m), 28mm FF (46° vertical 65° horizontal)
- EF-610 DG Super : 35(m), 28mm FF (46° vertical 65° horizontal)
Note the coverage for the AF280T. This is far short of an apples-to-apples comparison, but at the very least shows that published GNs are often not an appropriate basis for comparison without a few qualifiers. To be honest, I was surprised. I did not expect the Viv to equal the Sigma at similar coverage. Of course, there is always the accuracy of the guide numbers themselves. For that I would need a flash meter.
* Determined against blank wall to point of visible vignette (24mm APS-C) with zero vignette at 28mm on APS-C. Coverage for the AF280T has been variously stated from a wide of 28mm to as long as 50mm. The manual indicates improved performance with the wide angle adapter at 35mm, so maximum coverage without of about 40mm is appropriate and consistent with my quick test. With the WA adapter, coverage increases to 24mm with a published drop in GN to 14(m).
