Originally posted by stevebrot I know what that text does, but would caution that it will get everything...need big hard drive...and might be shut down if detected as a denial of service attack.
I pulled a gig before I had to stop, seems to have gotten most of the important stuff like manuals. It ended up digging deep into the community (forums) part, seems like there's a lot of stuff there and it might take a while to archive it all. Hoping I haven't missed anything by not progressing to whatever part may or may not come after the community section.
But no DDoS protection issues - maybe my connection is just too slow, which in this case would be a good thing.
---------- Post added 12-18-20 at 06:15 PM ----------
Originally posted by MarkJerling I'm not even convinced it will work. The updater for Cactus is an installer and the actual update is then installed directly to the flash or trigger, by means of the installer. The installer does not collect the update from the website, but probably somewhere off a server.
Weeeellll, technically you could capture the traffic and configure your hosts file to pull the file from localhost, i.e. a server running on your machine. That way, the installer would still work - it would think it's connecting to the remote server when in fact it's just connecting back to your own machine.
But you're right - I wouldn't have captured the file from whichever server it needs to come from as I didn't run any of the downloaded software, nor do I know if it will let me do that without having the relevant gear with old firmware on it.
But perhaps they'll be responsive to feedback, and publish the files? It would be a way to bow out with grace.
