thank you all very much, the conversation was constructive, this convinced me to decide what to buy:
- Recycling for the current AF360 is 6 seconds * compared to 3 seconds with the AF540FGZ II
- The K-1 supports AF assistance on the AF360FGZ II and AF540FGZII, not on the mk I. This is a nice feature to have.
- You will get more light from point 540II, which is useful in longer range, when limiting light, using fast synchronization or with modifiers.
- Get a more powerful flash. At some point you will be limited by the output of 360. Then you will wish you had a more powerful flash.
- You can operate the 540 in both P-TTL and manual mode to produce less than maximum power. You can’t ask the 360 to produce more.
- ............54 / 10m = f / 5.4 .................. 36 / 10m = f / 3.6
- As for the recycling time, they are probably about the same if you consider to get the same 360II light output at full power as if you used 540II at a 1/2 power setting
therefore, a flash was purchased:
Pentax AF 540 FGZ ll
first impressions:
1 -looks smaller 540 FGZ ll on K1 than AF 360 on K1, and is smaller but the stroboscopic lamp is larger
2 -it seems to be made much stronger than the AF360 FGZ (much much stronger-much more powerful)
3 -LED lamp reflects well with the for help focusing on K1 + FA80-320 / 4,5-5,6
4 -LED lamp in auxiliary lighting itself adjusts the light intensity in pttl mode
5 -I think the 540 FGZ ll has a faster response than the AF 360 (in focusing and recycling in pttl mode)
6 -in general I think that 540 FGZ ll is in the top of the 1st league while AF 360 FGZ would be in the middle of the second league, ie 540 FGZ ll is for professionals and AF 360 FGZ is for amateurs and advanced users (I'm not a
professional
i am so happy with the AF540FGZ ll as a toddler when he gets his most coveted toy (over 10 years I have used AF 360FGZ-so much desired change)
once again a big thank you to everyone, and all the best in the new year
