Originally posted by stevebrot The difference between the two is 1.5x greater reach, 20% lower battery life, and 60g greater weight with the AF560FGZ II. Moving up to either will get you swivel, WR, metal foot, improved battery door, and LED modeling light. Both should work with your current flash for optical wireless P-TTL.
The difference between the two is 1.5x greater reach - it's a nice increase (the range was enough for me on the AF360, but shouting range is not bad to have)
20% lower battery life - eneloop batteries work wonders (I use them, both white and black)
and 60g greater - not crucial, reportedly the size is the same as af360fgz
but
which is with the flash recycling rate in pttl (supposedly 540 is recycled 2 approx. 3 seconds longer, that would be a big problem for me,
which is with light help when focusing (flash reflection when focusing would mean a lot to me)
specifically the essential differences between them in possibilities
here on the forum 540fgz ll has a lower estimate of value than 360fgz ll
