Originally posted by gatorguy Mine was an Open box return at Adorama and made for Fuji. The flash doesn't care what camera it was made for when it's used as a slave off-camera. ...
Uh... it depends. Mostly/sorta true until it isn't.
I have a TT350-O for my Panasonic GX-7. It works fine with my XPro-O as a radio slave and on-camera. But when I try to slave it to the XPro-C on my 5DMkII? No TTL. Only fires at full power. I do get HSS and M power control. And using the XPro-F on my X100T, it's fine: TTL, HSS, everything. And some folks report that the TT350-S also works in TTL from a Nikon Godox transmitter and vice versa. But I think it may depend upon the specific combination of gear you're using.
When I complained about the Canon TTL incompatibility to Flashpoint support (brands@adorama.com; not their regular support), I was told categorically that the TT350 is
not designed to do cross-brand TTL. And the firmware updates have never added that compatibility, the way it's added to the other Godox system lights, like the AD Witstros and the full-sized TTL speedlights (TT685, V860II, V1). I've never had issues with my TT685-C being used across all three of my transmitters.
A lot of sites make the claim of Godox gear being completely cross-brand compatible, without noting specific exceptions, like the TT350/V350, and that only the Canon version of the TT685 being upgradable to be Pentax P-TTL compatible (no idea why only the Canon version, since all flavors of the V860II got that firmware update).
Also feel I should point out that while the TT350 is really great and I own one and love it, it does have some shortcomings compared to a full-sized Godox speedlight. It is slower to recycle (being powered only by 2xAA), and it's a stop less powerful. Its head only swivels 270º, not 360º (in landscape orientation, you're missing the quadrant to the left behind you, which sucks for bouncing). It has no recycle beep. No sync port, and no external battery pack port.
All of which are issues a $60 TT600 doesn't have (it just can't do TTL, is single-pin so hotshoe use is limited, and cannot be firmware upgraded).
The li-on version of the TT350, the V350, has never gotten a Pentax version. The TT350 also tends not to get firmware updated as frequently/quickly as the full-sized models. For example, the ID function was added in a firmware update for the TT685-C on Dec. 2017. Took until Aug of 2018 before the TT350-C got it.
Harder for you guys, though, not to go for a TT350-P since Godox never came out with a TT685-P or V860 II-P and a V1-P is so expensive. (sigh).
