11-15-2008, 09:41 AM   #1
JCSullivan's Avatar
Vivitar 283 and 285 and ringflash voltage
I spent a little of today documenting the voltages of my flashes and some of them are real woppers... 263 volts... ouch!
Vivitar 283 and Vivitar 285 voltage Et cetera!!!
11-15-2008, 10:24 AM   #2
Behold! The GBFO List of Flash Trigger Voltages!
Photo Strobe Trigger Voltages
Some of those are insanely high. I think (DO NOT quote me on this!) the K20D can handle high voltages, but I don't know if that's just through the PC Sync terminal.
11-15-2008, 11:00 AM   #3
QuoteOriginally posted by JCSullivan Quote
Can you folks explain how I can measure the voltage on my flashes? I have a multimeter but want to know the procedure for checking.
I also have Vivitar 283 and a couple of Vivitar 285 as well as a Nikon SB-24. I note that the SB-24 apparently has <6v according to the trigger voltage link but I want to check or myself as I don't want to 'fry' my camera.
thx
11-15-2008, 11:56 AM   #4
It's pretty simple. Grab a voltmeter, and apply one probe to the center contact on the shoe, and the other probe to the other contact on the side of the shoe (point the flash away from your eyes). If you get a reading in negative numbers, reverse the probes. Read what the voltmeter says (ie 200 volts), and then, while keeping the probes attached to the contacts on the flash, fire off a couple of test pops, and read the voltage throughout the test.
11-15-2008, 07:48 PM   #5
geauxpez's Avatar
PentHassyKon -- go ahead & check your voltages, but your SB-24 should be fine. I have 2 that I use on my hotshoe.
11-15-2008, 08:00 PM   #6
QuoteOriginally posted by geauxpez Quote
thx!
I did ask on a separate thread specifically about using Nikon flashes and was told that it would be fine.
I do however also want to check my 283/285 flahses.
I've also got a Pentax AF400T and was wondering about it's compatability with the K2000/k200d/k20d bodies.
Keep in mind that I've yet to get a DSLR and just want to be prepared when I do!
11-16-2008, 07:12 AM   #7
JCSullivan's Avatar
Jeff Geerling has a very GOOD tutorial here Measuring the Voltage on a Vivitar 285 or 285HV Flash Head - Life is a Prayer.com
Lithos, what is a GBFO???? Or you trying to be funny!
12-27-2009, 09:38 AM   #8
I measured 170V on my Vivitar 283 is there a risk for my Pentax K2000? I cannot find the maximum hotshoe voltage in my ****en' manual.
12-27-2009, 01:18 PM   #9
Steinback's Avatar
@Pentaxoid - Strobe trigger voltages are discussed quite a bit online but unfortunately most manufacturers don't release a maximum voltage that their camera hotshoes are guaranteed to handle. Anything under 24v is probably safe, and over that you are taking your chances. My flashes are all trigger between 5v and 12v.
Seeing as you could pick up a replacement Vivitar 283 or 285 with a ~6 volt sync for about $50 it's probably time to retire your current flash to off camera use only.
flash, lighting, photo studio, strobist, vivitar, voltage
Vivitar 285 on a K-x? MXman Pentax DSLR Discussion 15 08-14-2011 07:08 PM
RF-602 flash trigger + Vivitar 283 (old high voltage version) = Success? Failure? sfdealer Troubleshooting and Beginner Help 0 09-01-2009 07:03 PM
Vivitar 283 & 285 flashes - help please axl Flashes, Lighting, and Studio 11 04-07-2009 05:16 PM
For Sale - Sold: Vivitar 285 HV Yale Quan Sold Items 4 11-24-2008 07:48 PM
help!!! vivitar 285 Yale Quan Pentax Camera and Field Accessories 10 10-05-2008 09:32 PM
All times are GMT -7. The time now is 06:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
