Originally posted by plis
Flash is set to PTTL HSS (in PTTL, 1/90 is the shortest) and shows readiness itself and on the camera.
Assuming the Metz is on the camera hot shoe, it should work. The other assumption is that the mounted lens is A-series or newer and that the aperture ring (if equipped) is in the "A" position to allow P-TTL.
HSS as with all P-TTL features including sync is not handled through the main sync contact on the shoe. Instead, it is managed through the data contact at upper right. You can test whether P-TTL is working by going to M-mode with 2s delay for the drive mode. The preflash will fire on shutter press with the main flash firing after the delay.
There is also the outside possibility that a firmware update on the flash may help.
mecablitz 52 AF-1 digital: Metz
P.S. The sequence for half-step shutter speeds should be 60, 90, 125, 180, 250. For one-third-step...60, 80, 100, 125, 160, 200, 250 unless a Pentax-dedicated flash is detected. In that case it goes 125, 160, 180.
