04-20-2021, 11:57 PM   #1
LittleSkink's Avatar
Anyone recommend me a reliable / controllable ring flash?
Need a ring flash, ideally one that has some control over light / shadow, like the Sigma 140
Been offered a 140 but from reading around it doesn't always play nice with modern cameras, and if it needs a firmware update has to go back to Sigma. Also seen a Metz 15, more money than Sigma, but I like Metz stuff
Its for macro up to 2m away
04-21-2021, 12:37 AM   #2
pjv
Otis Memorial Pentaxian
pjv's Avatar
QuoteOriginally posted by LittleSkink Quote
I own the Sigma 140, and find that it works very well. I'm not sure what you have heard, but my 1st hand experience with it has been excellent. I have never thought mine needed a firmware update, as it does everything I ask of it. " Not playing nice " could be because of user error or inexperience.
Below are the reviews on the forums (mine included), which I stand by 100%. It is a great piece of kit IMO.
Sigma EM-140 DG Ring flash reviews - Pentax Camera Accessory Review Database
EDIT - I have never used it at 2m, as I use it exclusively for close-up flash.
04-21-2021, 02:10 AM   #3
Paul the Sunman's Avatar
I've not had any issues with the EM-140 DG either, though I've far from exhausted its possibilities.
04-21-2021, 02:25 AM   #4
thanks folks
It appears the Sigma 140 doesn't work well with K1 as the Pentax variant was designed for APSC, not FF. Most other issues seem to be with Canon/Nikon
How heavy is the flash tube? One potential use I have for it is on a 55-300, and I dont think the lens is robust enough
04-21-2021, 02:48 AM   #5
pjv
pjv's Avatar
Most of the weight is in the hotshoe part of the unit. But, extra weight on the filter thread end of any lens will increase the torque required to autofocus, either screw-drive or internal motor. Internal focus lenses are not affected, so manual focus is recommended for screw-drive, or for lenses that change length with focus..
04-21-2021, 02:58 AM   #6
thanks folks
It's pretty light. I use it on the Tamron 90 macro, for which the inner plastic tube extends about 6 cm from the lens body, and have not been concerned with the weight.
I use the 140 on my K1 without any problems, but have only tried it for macro. As you can see, the illumination is pretty even.
04-21-2021, 03:10 AM   #7
pjv
pjv's Avatar
Ethically speaking, I don't usually link my own threads, but I started the one linked below when I got my Siggy 140. It was started to get advice, and also for the members to share their flash images. Most of my images are the 140........
" FLASHERS " wanted here - PentaxForums.com
04-21-2021, 09:55 AM   #8
MossyRocks's Avatar
Someone else asked a question I have had in the back of my mind. Looking forward to others recommendations also.
04-21-2021, 11:18 AM   #9
Huh? I have never heard of a flash that was format-dependent. Are you saying that it has inadequate angle of view or is the reported problem something else? FWIW...the EM-140 DG dates back to film photography days and supports off-the-film TTL for 35mm cameras.
Edit: There are known issues with close-up photography and P-TTL when using non-AF KA lenses. The full explanation requires several hundred words, but the short description is that severe overexposure is not uncommon. Manual technique is strongly suggested when doing close-up P-TTL work with other than auto-focus lenses.
04-21-2021, 11:56 AM   #10
11GTCS's Avatar
I mean honestly most of the time I shoot manual macro flash anyway, so even my old Pentax 140 is fine for me. But I also have a Sigma 140. Great flash, and has a lot of modern features. I know the flashpoint/Godox full manual also gets a lot of decent press, especially for the price.
flash, lighting, photo studio, sigma, strobist
O-Flash, ring flash alternative. Anyone tried? mikeSF Flashes, Lighting, and Studio 29 09-12-2017 09:02 AM
If anyone asks me to recommend a starter DSLR... Scintilla Pentax K-30 & K-50 8 05-28-2014 09:03 AM
Recommend me a Macro Flash Please! lightbulb Flashes, Lighting, and Studio 9 03-17-2013 04:23 PM
Anyone has a reliable contact for service from sigma Canada or USA? bdery Flashes, Lighting, and Studio 3 06-24-2011 06:45 PM
recommend me a flash under $120 please! dinneenp Flashes, Lighting, and Studio 12 11-19-2010 12:01 PM
All times are GMT -7. The time now is 06:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
