Originally posted by Smoke665 Doing a little reading last night on how P-TTL actually works. Apparently there's more user input required then the marketing hype leads you to believe. Haven't had the opportunity to test it out, but it seems using both camera EC and flash EC is necessary. I also suspect that it is somewhat dependent on what your camera exposure metering mode is set to. Normally I leave it on Spot, but I was recently at an event where I switched to Matrix, and forgot to change it back.
The same writeup I was reading also mentioned using camera manual and setting the flash to P-TTL. I was unaware that was possible. I had erroneously assumed that you had to use both on Manual. I forsee more experiments ahead.
It is not well-appreciated, but P-TTL flashes take their orders from the camera. In short, they never over/under-expose unless told to do so or left with no other alternative (error conditions).
At core is the simple fact that the camera is serving as a TTL version of a flash meter with all the normal potential shortcomings of TTL light metering. Based on the meter reading, the flash is instructed on how much intensity to provide. If presented with a blank white wall, the meter will center the histogram with a "proper", though somewhat gray-looking exposure. If presented with a gray-toned gallery wall, the results will be equally proper, but more true.
Yes, camera metering mode is important. For best results, use matrix metering or center-weighted. Spot metering, even for non-flash photos, is a specialized tool and a sure guarantee for poor exposures unless used with a specific purpose in mind.* I tried, but could not think of a use case for spot metering with flash photography.
In-camera flash EC on my setup (K-3 and Sigma EF 610 DG Super) is additive to on-flash P-TTL EC. The genera exposure comp applies to ambient light, but will have an effect overall when flash is part of the mix.
Sometimes old-school manual flash using distance and guide number can be useful in diagnosing. I took the conditions from your second (manual flash) example and back calculated what the guide number exposure should be. According the tables in the user guide, the flash exposure in your example is about two stops over, based solely on ISO and distance.
* Exposure problems are a common help topic on this site and one of the most frequent causes for unexpected over/under exposure is use of spot metering for general photography. Unless one really wants Aunty Ida's face to be rather middle grayish, it is best to avoid spot unless wanting to place exposure (think Zone System) when using M mode.
