Sorry for the late reply. I keep forgetting you guys sometimes need your non-Pentax shooting resident Godox wonk.
Originally posted by stevebrot The last I looked, the list of update able TT685 and V860 models was in flux. Do you know if there is a full list somewhere of models that may be controlled from the Pentax-flavored flash and controllers?...
Just FYI, still no word on a TT685-P, but
the rumors are flying, based on
this 2021 Godox catalog, that sometime this calendar year, the V860 II is about to be replaced by a V860 III.
That catalog lists a Pentax version (however, they also don't list a Pentax version for the TT350, so... grain of salt).
AFAIK, it's going to use the V1 battery, has a "modeling light", on-camera TCM (i.e., not as a radio master) and a slide lock instead of the screw lock. I'm assuming it's probably going to gain some of the V1 improvements (SCAN function, better radio master UI, etc.) But detailed specs/reviews are obviously not available, yet.
The V850 II is also getting upgraded to a V850 III. I'm crossing my fingers that this time it's firmware updatable, and that the improvements eventually roll downhill to updated TT685 and TT600 models.
---------- Post added 05-26-21 at 04:54 PM ----------
Quote: Strange. I thought the TT685O for sure would work with TTL cross-brand.
Can't. The only TT685 that can be updated to work with P-TTL is the TT685-
C (Canon version). No #$^@&ing idea why only that one flavor. All flavors of the V860 II, however, can be P-TTL capable with a firmware update.
Quote: As far as TTL triggers and flashes for specific cameras, I thought the main reason was the hot shoes are different physically on each camera brand. There are different number of pins, at different locations, used for different purposes.
This is true. But, MFT, Canon, and Fuji actually use the same pin/contact placement location and patterns. So it's not just the physical pin/contact placement but also the electronic communication protocol differences that have separate versions for everything.
Quote: Of course, the TTL protocols are different for each brand too. But if not for the physically different hot shoe, they could have a single firmware that handled all the brands, with a setting in the menu to choose your camera brand.
Yup, Jinbei and Cactus have both proven they can cover multiple brands of hotshoe with a single pin arrangement, so it's not like custom-fit feet/hotshoes are required for 3rd party gear. Just that Godox prefers to do it that way. Godox also does go some way in imitating labelling of OEM brands, so what is called MULTI on other flavors is called RPT on Nikon, etc. So, the display communication is also different (assuming a dot-matrix LCD; if not, then the LCD hardware is different, too).
Quote: I bet if you could swap the hot-shoe and reflash the firmware for your brand of camera, it would likely work....
Uh, no. I have seen a lot of people make this assumption on a number of different boards, ignore my warnings, and try it only to find out they've wasted their time and money. It will not work. I'm assuming some of the brand-specific stuff (like the LCD display names) is hardwired in the chips/boards, not just firmware.
Loading the wrong firmware image to the device results in the E9 error the OP saw earlier.
