Originally posted by bladerunner6 What are the advantages of the other controllers versus this one please?
The
Flashpoint R2 Pro MarkII is the best trigger, in my view.
It combines the functions of all the others (Bluetooth, channel scan, etc.), whereas the X2T and the XPro only give you a subset of the features respectively.
It has the best ergonomics because it saves you menu-diving and multiple button presses due to having more dedicated buttons. This results in some duplication of function availability, but the latter is not really a problem. It's buttons are backlit and the group buttons are arranged around the dial, so there is less finger/hand movement when you adjust power levels. Toggling groups is done efficiently by just double-tapping group buttons. The other triggers require a cumbersome use of the mode button and cycling through three options for groups A-C just to toggle a group on and off.
It's only potential downsides are that it is a bit bigger and unlike the X2T, it does not offer a hot-shoe connector. However, it trades the hot-shoe connection for a much larger display. Some users find the front-facing display of the X2T easy to read when the camera is mounted high on a tripod, for instance. In my view, the number of scenarios where the tilted displays of the XPro or the R2 Pro MarkII work better is much higher.
At $69 it is cheap enough that I would give it the nod any time of the day.
