Originally posted by mctaveck Hi guys,
i read this thread but i didn't find a real answer to my question, so here it is:
I have this amigos
* the Yongnuo cotroller (let's call it transmitter) YN560-TX in the hotshoe of a K3 mark III
* the Yongnuo RF603N II,
* the Pentax AF540FGZ flash unit
* the Yongnuo 560 III flash unit
do you guys think I can change the power using the controller (transmitter) so that the Pentax flash will rise or decrease the flash power ?
I set up everything (the flashes upon the receivers in TRX mode, the flashes in M mode) and the and I try everything but i can just use the flashes (both!) full power (1/1).
Thanks for any help
Danilo
Danilo, with the YN560TX on the camera and the YN560III flash off-camera, you can trigger the flash and also control the flash power level from the YN560TX.
With the YN560TX on the camera and the RF603N II attached to the Pentax AF540FGZ off-camera, you can trigger the flash, but you can not adjust the power level from the YN560TX. To adjust the power level of the Pentax flash you must do that on the flash itself.
