Hi, there. I'm planning my K20d system, and as regards flash units, my dinosaureyness is showing. (I've just never had a camera where there was any point to anything much fancier than a 285,
So, I'd appreciate any help getting my bearings with what's out there for what, compatibilities and compromises, etc.
Much elucidation follows:
It looks to me that between Pentax and Metz, there's some current full-service big units to pick from when it comes to shelling out for something like that. (Though any bargains here could be useful.)
With anything, the fancies I'm most interested in are TTL metering and AF assist, preferably of the beam type.
(In general, I'm wondering how much backwards or forward compatibility there may be between things that might have been made for older Pentax models, this could come in handy later or make a nice Ebay score or something.)
Firstly, though, I'm somewhat interested in a smaller unit... Power's not a priority: enough to handle a nice amount of diffusion at a bit better than pop-up flash ranges would suffice. (I'll probably start by seeing what I get putting one of those little diffusers on the popup flash, actually. Something fairly thin and blazer-pocket-sized would be sweet: something about the size of a non-bouncey kit flash from the 80s would be fine. (Actually it's this sort of thing that makes me think just maybe there's something with a focus assist lamp and TTL that might just be compatible,)
Which.. leads me to wonder what you get with the current smallest flash Pentax makes. Obviously few bells and whistles, no lamps to avoid obtrusive pre-flashes with... question being what *do* you get.
Secondary question: if you have the mid-sized current Pentax unit, can you use the pop up flash for fill while bounce-carding the flash unit or whatever? That might be useful enough to me to justify the size.
Thanks in advance, ...if there's a FAQ on this sort of thing, it'd probably be handy.
