US$229 / CAD$ 291 / €225 / £193
Lencarta [Pentax and Olympus versions grayed out for now]
Adorama B&H
It's basically a V1 with a traditional fresnel head.
They've ported most of the physical UI changes between the V860 II and V1 to this one. So, slide lock, LED modeling lamp, head tilts back 30º, TCM button, new 4-way dpad/control wheel with 0.1EV adjustments in M mode; SCAN function, dropped smart optical support, etc. C.Fn menu is identical to the V1's.
Also uses the same battery pack as the V1, so only 2x the lifespan of a set of 4xAA, vs. 2.8x, like on the V860 II with the older pack. (I had it explained to me on dpreview that Godox moved to use the more-standard/high volume 18650 cells ("the AAs of the li-ion world") that are commonly used in vapes. I was puzzled at how a pack with a higher charge capacity (2700 mAh vs. 2000 mAh) meant fewer full-power bursts, and it was pointed out that charge is not energy
, and I eventually figured out energy = charge*voltage, and the voltage on the new packs dropped to 7.2V from 11.1V on the old, which is why the old packs had 22.2 Wh, but the new ones only have 18.7 Wh.
Reason: edit title.
