UPDATE:
THANKS TO ONE OLD MOD AND ONE NEW MOD, MY CACTUS TRIGGER IS NOW WORKING WELL - SEE LAST POST.
Old post:
Some stuff i've learned along the way:
1. When Pentax literature talks about wireless, they are talking about a flash optical signal to trigger the remote flash. That has nothing to do with the "radio" wireless flashes such as the Cactus made by Gadget Infinity, ebay store.
2. To activate the Cactus Transmitter, its slid into place on the hotshoe, and the camera is placed in the "manual" mode, flash is selected from the FN menu, not "wireless flash (if i'm wrong on this, pls tell me). The Receiver is attached to the base of the flash.
3. The Cactus Version 2 triggers have 4 possible radio channels. When i first tried the trigger, the flash was being activated every 10 seconds or so without any shutter action. Changing to a channel with less interference solved this problem, as recommended by the instructions.
4. The manual says these triggers only work up to a maximum of 10 meters or 30 feet. Trying them tonight, they worked at 45 feet w/o anything interferring with the signal.
5. There have been times the past few 2 days when the radio triggers just didn't work every time. Didn't get to the cause of these problems. Commonly, my Metz Flash would timeout after 10 minutes and i had to go reactivate it again. It can't be set any higher than 10 minutes. I was playing around with different shutter speeds and apertures, and i'm wondering if some of this caused a problem with the flash. In some cases i saw the flash go off and it didn't show up in the picture. Perhaps the shutter was not at an acceptable synch speed to catch the flash. Or perhaps some radio interference caused the occasional malfunction.
Anyway, these radio triggers are reliable enough to satisfy the casual user like myself. Please note if you have any tips on them, including using on multiple flashes.
thanks,
