Originally posted by PocketPixels I'm in Av mode, with no flash attached, and my exposure is ISO 400, f/2.8, 1/120s. If I adjust EV on my camera (not FEC) by -1, the camera will change the exposure from ISO 400, f/2.8, 1/120s to ISO 400, f/2.8, 1/60s. Right?
Yes. (Not just in theory, I tested it with the K-S2 to be sure!)
Originally posted by PocketPixels I'm in Av mode, with the FlashPoint Mini Zoom attached in TTL mode, and my exposure is ISO 400, f/2.8, 1/120s. If I adjust EV on my camera (not FEC) by -1, the camera exposure will stay at ISO 400, f/2.8, 1/120s, but the flash will reduce its output by 50%. Right?
I tried this (K-S2 in Av mode with fixed ISO, TT350P in the hotshoe in PTTL mode) and that's how it worked. I tried 0EV, -1EV and -2EV (on the camera's exposure setting only, not FEC). The camera did not change the shutter speed, just the flash output.
I should add that the reduction in flash output between 0EV and -2EV didn't look to me like 2 stops. (That is just a subjective impression, not metered.) Maybe that's a quirk of the metering - Steve might have a better explanation. Anyway, when I tried again adjusting only the FEC on the flash instead, not the exposure setting on the camera, the reduction in output from 0EV to -1EV to -2EV was more marked - it looked like 1 stop and 2 stops respectively. My take home point is that adjusting FEC rather than camera's exposure adjustment seems to give more predictable and accurate results. Which would matter in product photography or shooting a wedding.
