Nearly all of my professional work is product photography, where nothing moves, most things sit still in a light box, and I can re-shoot anything that doesn't look great. I use an old Pentax AF 140C ring flash on the (rare) occasions when I need more light.
I rarely use flash at all, and for years I thought "P-TTL" and "TTL" were the same thing, roughly translating as "The flash will talk to your camera and lens, and it will respond as well or better than your on-camera flash will as lighting and zoom changes." Anyone who has ever connected a 1990s AF 140C ring to a 2017 K-S2 knows that's not true.
So, is the FlashPoint mini zoom P-TTL? It doesn't say so anywhere on the device or in the manual. Yet the manual specifies that it has been tested and developed for the K-S2, K-70, K-1, and K-1 mkii cameras. None of these cameras are TTL; they are all P-TTL. Anybody know how well I can control this from my camera? Or, broadly, what test shots I should make to learn the ropes on this new equipment before i go use it on a shoot?
I'll be at my cousin's much-delayed wedding reception next weekend, and I'll be the only "serious" photographer there. (She spent her photo budget on the actual wedding, which was limited to only a few guests due to coronavirus concerns.) I have a FlashPoint Zoom Mini-Flash, which I believe is very similar to a
GoDox Flash.
I am NOT the hired photographer; I am not going to get sued or drummed out of the family if my photos of this event are too dark. (Actually, if the flash doesn't work well, I'll switch to available light and motion-blur dance shots.)
My gear is listed in my signature (at least if you read this on a computer). I plan to bring my K-S2, 21mm Limited, 70mm Limited, 10–17mm fisheye, and my Helios 44 55mm f/2 (which I may use only for tripod posed photos against the harbor lights, as it is a very fussy lens.) The fisheye is too wide for any flash, and the Helios is a novelty lens, so mostly I'll be using the 21mm and 70mm for my flash shots.
