I have a K200D with
Sigma 530 DG Super flash and they're a wonderful combination and I can use K200D onboard flash to trigger Sigma 530 DG
Super off the body.
But was wondering if I bought a
Sigma 530 DG GT and mounted it on K200D, would I be able to trigger the Sigma 530 DG
Super externally ? Or would I need another Sigma 530 DG
Super to be able to trigger my existing Sigma 530 DG
Super ?
The Sigma 530 DG Super description:
Quote: Slave Flash
The Designated Slave function allows you use of two or more EF-530 DG SUPER flash units and also flashguns can fire together by using the channel settings. Since the EF-530 DG SUPER is equipped with this function, it can be used with all camera models. It is also possible to use the camera’s built-in flash or another flash unit in Normal Slave mode (Flash Exposure must be adjusted manually).
Anyone tried ?
thanks
George
