Originally posted by pjv Many thanks, Peter, looking forward it.
OK , I think I have the answer. I used Pentax K1 with AF540FGZ II on the camera. The AF360FGZ (version I) was off the camera.
AF360 set to Slave 1
P-TTL works normally with both flashes contributing to exposure (or just AF360 contributing if the AF540 is set to Controller)
AF360 set to Slave 2
Only options available on the AF360 in SL 2 mode are Manual and Auto (thyristor)
With the AF540 set to P-TTL the AF360 fires on the pre-flash (dumb reaction) so does not contribute to the actual exposure.
With the AF540 set to Manual mode (Manual mode required on camera too) the AF360 fires correctly in both Manual and Auto (thyristor) modes , contributing to the exposure.
I also put my Cactus RF60X on the K1. In Manual Flash mode it also correctly triggered the AF360 (in SL2). Even removing the Cactus from the hot shoe and pressing the test button caused the AF360 to fire.
Hope this helps.
ps. when using the AF360FGZ as a slave in either mode 1 or 2 you need to have the on/off switch set to wireless and the M/C/S switch set to S
---------- Post added 11-20-21 at 12:33 PM ----------
Originally posted by noblepa I still am not sure if the AF360 can function as a simple optical slave, in the absence of a pttl capable camera.
Yes. Slave mode 2 on the AF360.....on/off switch set to wireless and the M/C/S switch set to S. Your triggering flash must be a single burst (no pre-flash), and you must have line-of-sight between the two units.
