Originally posted by bladerunner6 I have a couple of these I have been using with 24 by 24 reflective soft boxes.
I have a chance to buy a variety of bigger ones as big as 48 by 48.
Any opinions on this, please?
Thanks.
48x48 might be a bit much for that flash. At one time I used a Metz 60 series flash in a 2x2 sotbox and was able to shoot at f5.6, IIRC with ISO400 film with the box a few feet from the subject.
The Yongnuo 560 flash is about the same guide number as my old Metz.
A 4x4 box will require you open up a couple of stops, so if my remembery is correct, you will be in the f2.8 range at ISO400.
I have a gigantic modifier called a moonlight. It's a 60" diameter monster. I never did have a room big enough to do it justice. The light from it was too flat. A big modifier let's you move the light further away which is nice, but then power demands start to increase dramatically. Double the distance from light to subject and you need 4 times the light output to keep everything else the same.
