03-03-2022, 02:26 AM   #1
Is it possible to link up Metz 58, Pentax 360 and Pentax 540 flashes
I've acquired a Metz 58, Pentax 360 and Pentax 540 flashes. I've only ever used them on camera tbh. Can any combinations of these be linked on or off camera?
If not, what should I keep and which Godox system or similar would help?
03-03-2022, 03:39 AM   #2
Paul the Sunman's Avatar
They're all P-TTL capable (assuming the Metz is the Pentax version), so yes, they can all be used together. Use one on the camera and the other two wherever you want, and they will communicate optically.
03-03-2022, 07:38 AM   #3
pschlute's Avatar
QuoteOriginally posted by BrianCoup Quote
I don't have the Metz, but I have used the AF540 and AF360 together with a Cactus RF60X, all triggered by Cactus radio triggers. Sadly, Cactus are no more, but your flashes should all work together with any decent radio triggers, as well as optically.
03-03-2022, 08:39 AM   #4
bdery's Avatar
The simplest option is to use the 540 as the wireless PTTL master, and the others as wireless optical slaves. They are all capable of doing that. You don't control them individually, the camera will tell them how they should fire.
You can also control them manually, set the power on each, and use optical slave in manual instead of PTTL. One flash on camera (which must be in manual also to avoid messing up exposure) and the others will fire when they see the first one firing. Some back and forth to set the results to how you want them, but once you're set, exposure should remain constant as long as the scene doesn't change.
You can get radio manual triggers, which will do the same thing, but will let you place the three flashes off-camera. Again, manual control is the only thing available.
03-03-2022, 06:37 PM   #5
K2 to K50's Avatar
Sadly, Cactus are no more, ....
Wot!! Cactus have gone cactus??????
03-10-2022, 07:06 AM   #6
Thanks for all your responses about the flashes. It's not a subject I'm familiar with and even I could understand
camera, flash, flashes, lighting, link up metz, metz, pentax, photo studio, strobist
Metz 58 AF 2 flashes power pack and Metz company robert52 Flashes, Lighting, and Studio 5 03-15-2022 07:37 PM
Where is Metz 58 firmware? Not on Metz CA site, UK & DE Metz sites gone, no USA site Lititz Flashes, Lighting, and Studio 4 03-15-2021 02:10 PM
New Weather-Sealed Pentax AF 360 and AF 540 Flashes Adam Flashes, Lighting, and Studio 18 09-03-2013 03:22 AM
Metz 58, 48 or Pentax 360, 540 Sprags Flashes, Lighting, and Studio 22 06-07-2008 05:45 PM
All times are GMT -7. The time now is 12:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
