12-17-2008, 05:47 AM   #16
pcarfan's Avatar
I'm sort of just getting into flashes too. To get the flash to fire, try using a slower synch speed like 1/60 or something. Also, do you get a flash when you fire it in the test mode? Is there a test mode?
I've been using some used flashes in off camera mode by buying the cheap Cactus transmitter/receiver. Pretty simple to hook up and can't beat the cost.
good luck[/QUOTE]
The main flash works very well, I was just talking about the secondary fill flash. But, I will try different shutter speeds too this wknd.
12-17-2008, 05:48 AM   #17
pcarfan's Avatar
QuoteOriginally posted by JCSullivan Quote
This guy might have a manual for you JEB on Flickr - Photo Sharing!
I posted the question in his recent addition, and today i went back to see his response and found my question has been deleted, oh well.....
12-17-2008, 07:18 AM   #18
JCSullivan's Avatar
Try PMing or emailing him - he might not have been the one deleting the question.
12-17-2008, 03:10 PM   #19
pcarfan's Avatar
Yeah, I did that and got a reply, But, infortunately he doesn't know much about the flash and doesn't have the manual. But he did say that switches 1/2 is to choose whether to fire one flash or both, I guess mine is broken. But, the main flash is still good, so I can use that.
Thank you for your help.
12-18-2008, 05:40 AM   #20
pcarfan's Avatar
I fired some test shots with my 540 as the wireless slave (SL2), and this Black's flash on the hotshoe, and it works well in manual mode. I have to tweak the output and see whether I can get better resuts with this as opposed to the 540 alone. (I think I should). Test's will follow this wknd.
12-22-2008, 09:32 PM   #21
stewart_photo's Avatar
QuoteOriginally posted by pcarfan Quote
(snip) I hope you can explain how to read the guide number. (snip)
Sorry, when I said guide numbers, I should have been saying f-stop numbers (aperture settings). Since I don't have a clue on the guide number of the flash, there's no way for me to guess which f-stop settings to use. If you search around the internet, you might find the steps necessary to obtain the guide number for the flash yourself through a series of test exposures. It's can be done, but I haven't tried it in many years and certainly don't remember how.
I think that is to assign the flash for different camera models as you had suggested earlier
Of course. I asked which cameras are supported and then didn't associate that switch with the question. Obviously one of those "blond" moments.
I see you're now experimenting with the flash unit. That's your best bet at this point. Look around the internet for a method of obtaining the guide number and then do the math for that guide number versus flash distance to set the f-stop on the camera. At that point, you'll be almost home. Good luck.
stewart
flash, front, lighting, options, photo studio, strobist
For Sale - Sold: Sunpak Auto511 off-camera flash and bracket, Large Quantaray black camera bag pxpaulx Sold Items 3 02-11-2010 09:06 PM
Camera Exposure Compensation with Flash With camera in Manual Mode jrforman Flashes, Lighting, and Studio 0 09-11-2009 10:03 AM
Mixing off camera manual & on camera p-ttl flash srclark Pentax DSLR Discussion 8 12-29-2008 08:52 AM
Bouncing/diffusing on-camera flash (with sample images) hamidlmt Flashes, Lighting, and Studio 9 11-14-2008 02:25 AM
First images from new camera... Duh_Vinci Post Your Photos! 10 05-13-2007 06:45 AM
All times are GMT -7. The time now is 02:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
