05-11-2022, 08:50 AM   #1
AF-500 FTZ and Pentax 645 TTL compatibility
Hi guys, my first post here!
Recently I've read some positive reviews about good old AF-500 FTZ TTL flash unit here:
PENTAX AF 500FTZ reviews - Pentax Camera Accessory Review Database
After reading about the positive experiences with analog TTL cameras there (especially from user gofour3) I've decided to go for this flash to couple it with my Pentax 645 film camera.
Now the flash has arrived and to my disappointment it seems, that my 645 camera doesn't "understand" the TTL protocol of this flash. I conclude that from viewfinder, because when the AF-500 FTZ is attached and switched on, the little "lightning" icon doesn't appears in the viewfinder and that means the camera don't "sees" the attached flash. This, for example is not the case with my little Pentax AF220T - if I turn it on, the 645 automatically switches to TTL mode and shows the "lightning" icon in viewfinder.
The question: is AF-500 FTZ really incompatible with 645's TTL mode?..
Thanks in advance!
05-11-2022, 09:05 AM - 1 Like   #2
Not a Number's Avatar
Welcome to the Forums.
I moved this post to the Flash section. Hopefully someone can answer your questions.
05-11-2022, 09:41 AM - 1 Like   #3
The F series of flashes (as in FTZ) uses a digital control method which is only compatible with AF bodies. Your 645 uses an analogue control method which the AF500FTZ doesn't recognize. Flash Systems Evolution, Features and Operation | The K-Mount Page covers this, read down to the section on Digital-Control Flashes.
05-12-2022, 12:24 AM   #4
Thank you for your explanation!
But it leads me to conclusion, that the following statement on the before mentioned AF-500 FTZ Review page was rather false:
"While the AF500FTZ would not be your first choice for a Pentax DSLR, it is the flash of choice for any Pentax film camera that supports TTL flash. As a result I give it a 10, you are not going to find a better flash for a Pentax TTL supported 35mm, 645 or 6x7 film body. Highly recommended."
05-12-2022, 03:11 AM - 1 Like   #5
It might be your unit is defective or the contacts (camera and flash) just need cleaning. Or you've overlooked some setting?
Why not contact the poster @gofour3 for more information?
05-12-2022, 01:07 PM - 1 Like   #6
gofour3's Avatar
The older manual focus TTL film cameras, like the LX, Super A and 645, fully support only the first generation of 4P TTL flashes.
Auto focus 35mm & 645N/Nii cameras support the second generation 5P TTL auto focus flashes. The manual focus 67II also works, but only via the special hot-shoe grip & 5P flash sync cable.
My guess the older 645 will work but you will loose some flash features. Another issue is the camera mount not being KFA/KFA2, so you will loose the auto zoom features of the AF500FTZ flash.
Phil.
05-13-2022, 01:48 AM   #7
QuoteOriginally posted by gofour3 Quote
Phil.
Thanks for your input @gofour3.
I've tried the flash with 645 yesterday and it fired in Manual mode only. As expected. The TTL isn't a must in all situations, but I don't know yet if I'll keep this flash, because I was hoping for more.
I assume the "modest" solution could be AF280T, the fancy way could be something like battery powered studio flash - Godox? - with Radio Trigger.
05-13-2022, 08:51 AM - 1 Like   #8
gofour3's Avatar
QuoteOriginally posted by LocalFlover Quote
The AF400T, would be another option for the 645:
PENTAX AF 400T reviews - Pentax Camera Accessory Review Database
Phil.
645, af-500, af-500 ftz, camera, flash, ftz, ftz and pentax, pentax, pentax 645 ttl, pentax help, photography, troubleshooting, ttl, ttl compatibility, viewfinder
Flash diffuser for the Pentax AF 500 FTZ pkr1979 Pentax Camera and Field Accessories 16 12-03-2021 06:32 AM
Af.500 ftz dr5chrome Flashes, Lighting, and Studio 7 11-30-2021 05:24 AM
Pentax 67II and AF 500 FTZ? Fritzenpapa Pentax Medium Format 9 12-25-2013 01:06 PM
Pentax af 500 ftz and pentax istds question pimentel1980 Troubleshooting and Beginner Help 3 04-13-2013 04:02 AM
All times are GMT -7. The time now is 10:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
