Originally posted by pentaxian_tmb Thanks for the response. COuple of follow up questions. 1. WHat can the Godox V1 do that the AF360 fgz cannot do? 2. How difficult is the godox v1 to use/set up with the k5ii ? 3. If I use the godox, can I set up the AF360 off camera to fire in slave mode or based on the light from the on camera flash?
I noticed you have had a lot of responses. To answer your questions, The Godox V1 will give you more light, the longevity of the battery life of the V1 will give you far more dependable power, the V1 will operate with the K-5 IIs and you can set up the AF360FGZ to fire in optical slave mode (firing based on the light from the camera flash) with the V1 on camera if you would like to..
After seeing some of your responses to the questions, using the V1 on camera by itself with the dome diffuser may be an excellent solution for a lot of your needs of light. The important thing is that it would be efficient in a lot of situations. Another thing is that you have to make sure you know how to use it (V1). It is not difficult to use, but actually getting it, using it, and seeing the results you get from it will tell you what your preferences are and what settings you feel comfortable with. I had three AF360FGZs and they were what I learned a lot on, but the V1 will show you what it is like to shoot with excellent results and long lasting battery power. If I were you I would purchase the V1 and the dome diffuser and learn how to use by itself the way you feel comfortable with it. If you are not ready to use it for the first event you mentioned, you can approach the first event with your AF360FGZ.
If you do purchase the Godox V1 for Pentax, it will be a step that will advance your capability as a user. It is capable of firing other off camera Godox lights by itself as a transmitter as I mentioned in my first post, so if you decided to bring your off camera interests to a reliable level, you could purchase another V1 or other Godox light to accompany your original V1.
For now, to make it simple, I will tell you that I switched from the AF360FGZ and Yongnuo AA battery flashes to the Godox V1 and other Godox lights to have a dependable and excellent system and that is actually what it is. In your situation, I would recommend that you purchase the Godox V1 and go from there. You won't be disappointed. I think you will love it. When you get it you can test it on family and friends and you will see how nice of a tool it is. You can get the dome diffuser also and soften your light some with it if you want to.
To give you an idea of what using the V1 is like, I have placed a shortcut below to a video that shows the basic functions of the Godox V1. Using it on camera by itself is much more simple than using it as a transmitter for other Godox lights, but using it as a transmitter or off camera is something that can be learned too. An example would be that for simple operation for on camera single flash use, using it in Normal flash mode would be where you would start, and on that mode screen you would be able to switch between Manual and TTL and adjust your power. That screen is explained in the first minute or so of the tutorial video.
If you do purchase, make sure to get the Godox V1 for Pentax (specifically for Pentax).
Though others may recommend options other than the V1, I think it would be a valuable asset to satisfy what you have expressed as your needs.
