Originally posted by nskan Thanks for the replies. Anything I should know when shopping for a receiver/transmitter? I am going to be shooting the flash in manual.
You can get simple triggers, like Godox FC16 or Yongnuo RF603 II triggers. If there's a Nikon version, you'll probably want that one, since standby signalling can work between Pentax and Nikon triggers.
But. If you use the Shanny in manual on a radio trigger or in a "dumb" optical slave mode, the only communication you will have is to tell the flash to fire in sync. "Manual" doesn't just mean you have to use the flash in M mode (not TTL), but also that you have to adjust the power/zoom, etc. directly on the flash using its own physical controls, while keeping your shutter speed at or below your camera body's sync speed (K-5ii, that would be 1/180s).
If your softbox is mounted on a
bracket with the flash behind it, then this shouldn't be an issue. But there are some softboxes
where the flash is completely within the softbox, and to make
any adjustment, you'd have to rip open the softbox and then close it back up again. A lot less convenient.
If you want to avoid this, you could also consider trading in your Shanny for something like a Godox speedlight (say a TT600 for $65), which has a built-in radio transceiver that allows for remote power, group, and HSS control over the speedlight, and keep the Shanny for on-camera bounce flash.
