12-29-2008, 10:33 PM   #1
dws1117's Avatar
Flash how to question.
How do you trigger a flash that is held off camera without using the on board flash as the trigger? Do I need to buy something? What am I missing?
12-29-2008, 11:58 PM   #2
philbaum's Avatar
QuoteOriginally posted by dws1117 Quote
You have two options, using a cable from the camera, (not sure if you need a hotshoe adapter or can use a camera port), OR using a radio transmitter/receiver. I purchased the Gadget Infinity Cactus radio transmitter/reciver and it works fine for my amateur use. The transmitter slides into the camera hotshoe and the receiver slides onto the "foot" of the flash.
12-30-2008, 01:23 AM   #3
sharko's Avatar
G9Chon - FlashWaves
Trigger goes on camera, reciever goes with flash. Ummm...you can probably expect your flash count to increase after buying triggers. I went from 1 to like 5 now since the creative possibilities are endless with multiple flashes (place them all over a room, tie them to stuff, etc.)
12-30-2008, 03:34 AM   #4
stewart_photo's Avatar
Read the reviews on the various wireless triggering options (radio or infrared) very carefully before purchase because you'll quickly discover not all work as well as the others.
In general, the name-brand radio slaves (PocketWizard, MicroSync, etc) are popular exactly because they work. Infrared options (Wein, etc) work in a similar manner (multi-channel pulses using infrared instead of radio) and are not affected by radio interference. Products from name-brand studio lighting companies (Bowens, Elinchrom, Speedotron, etc) also tend to work reliably, with some of those compatible with most any flash and occasionally cheaper than the PocketWizards and MicroSyncs as well.
In my case, I purchased the Elinchrom EL-Skyport Universal Radio Slave Set for those latter reasons. The fact that I'm very satisfied with my Elinchrom studio lights obviously helped influence that decision.
stewart
12-30-2008, 06:02 AM   #5
Just for clarity
Why do you not want to use the on board flash. Just so that it does not light up the subject ?
If this is what you want... you can go into the menus on the k200d and set the flash as a controller rather than a master.
It will pre-flash, to trigger your off camera flash, but it will not fire for the actual picture.
You get wireless flash, w/o the on camera flash contributing to the picture.
Does that help ?
12-30-2008, 07:00 AM   #6
dws1117's Avatar
Thank you. All of this helps.
flash, lighting, photo studio, strobist, trigger
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
Yet another flash question... markos Flashes, Lighting, and Studio 10 09-01-2009 11:51 PM
Another flash question eccs19 Flashes, Lighting, and Studio 3 08-20-2009 11:23 AM
A question on Flash throndor Flashes, Lighting, and Studio 4 11-09-2008 09:21 AM
Flash Question - Turning Off Flash Quickly For a Shot sweetpapa Pentax DSLR Discussion 5 06-16-2008 12:04 AM
All times are GMT -7. The time now is 12:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
