Originally posted by hcarvalhoalves I buy and fix many things myself, including cameras, lenses, eletronics… I now own a good collection acquired on a discount.
Same here. The causes of breakdowns and scrappings (cars, cameras, washing machines) are usually tiny things like a worn bearing or a broken switch. Present day manufacturers seem to make such things difficult to replace deliberately, either physically difficult or by not making the part available. Recently I bought a new washing machine only because the old one's main bearing had failed, and the bearing could not be bought separately without buying the entire inner and outer drum assembly (at probably more cost than a new machine). I gather that the bearing was peened in place - possible a few pence cheaper to make but costing me £100s four years later.
Governments are part of the problem because politicians are mostly arts grads with no technical understanding - they look with horror on any technical work. Hence manufacturers like John Deere and Apple are getting away with effectively banning independent (let alone amateur) repairers (playing the "
Safety!" card). In the UK, working on your own house wiring and most central heating is now banned - cars will be next. I can understand a requirement for a competence test in some areas, but the way it is regulated is by "self-regulation" within electrical and plumbing companies (mostly small and local). Yet I had a plumber from a local company to look for a fault in my boiler and he was useless - afterwards I looked myself and found a water level sensor had simply failed. I reckon I can do a better plumbing or electrical joint than most professionals* anyway, partly because I am not under time and cost pressure.
[Rant over]
* I could argue I
am a professional, having been a ship's engineer, electronics lab engineer, and car workshop deputy foreman at times. I have repaired several flashguns too, this one I saved by replacing a loose screw:
Sunpak 555 / G4500DX Repair - PentaxForums.com
